Voice gateway
Oct 16th, 2008
I need to sizing a voice gateway for an IP telefony provider. He has an Ip PBX asterisk in G729 codec and want to comunicatte with PSTN with 4 E1 in G711 codec. The gateway would have to make trascoding of 120 channels.
I think in an Cisco2800 solution but I found the DSP problem with this solution.
I need aid to make the gateway sizing since never I had one of this size.
Thank you very much
Overall Rating: 3 (1 ratings)
Jaime Valencia Thu, 10/16/2008 - 15:17
you can play with the dsp calculator to find a suitable ISR for this, most probably you will need at least a 3725 or 3745 for the 2 E1s and the 120 transcoding sessions
java
if this helps, please rate
pablosorella Fri, 10/17/2008 - 04:32
I played with the DSP calculator and I am not sure about the Cisco3800 configuration is the best option.
Has Cisco another gateway option?, or is the 3800 the best option?
Thank you
Jaime Valencia Fri, 10/17/2008 - 04:41
please read carefully my previous post, i never mentioned 3800 series
java
Jaime Valencia Wed, 10/22/2008 - 08:02
sorry, was not aware of that. unfortunately any lower platform cannot support what you need for the E1s and the transcoding sessions
java
CHRIS CHARLEBOIS Wed, 10/22/2008 - 12:58
Why do you need so many transcoding sessions?
It might make more sense to split this between a couple 2800 series then to back up the Brinks truck for a 3800 series.
