Difficulties with Rejected IP Address and Netmask
jason.s.wallace
Friends,
I am configuring a Cisco 2610 (IOS 12.2, WIC-1DSU-T1) to operate with AT&T via a T1 for internet service. The IP address and netmask they provided are rejected by the 2610 via terminal and by ConfigMaker 2.6. According to my understanding of subnetting, the IP address they provided is a subnet address, not a valid host address. And, the address they say their router is on is the broadcast address for the previous subnet.
Can someone provide me with direction - Or better - a config file to make this work? Am I wrong about some instance?
Below are the specs they provided, NOTE: the IP addresses have been changed but I crafted them to suffer the same problem.
Customer Serial IP Address:
26.176.172.204 (a subnet address, not a host address?)
AT&T Router IP Address:
26.176.172.203 (a broadcast address for the previous subnet?)
Subnet Mask:
255.255.255.252
LAN Information:
LAN Block:
192.168.1.0/24
LAN/Ethernet/Gateway IP Address:
192.168.1.1
Broad Cast IP Address:
192.168.1.255
Subnet Mask:
255.255.255.0
Configuration:
Speed:
T1
Line Coding / Framing:
ESF/B8ZS
Serial Encapsulation:
PPP
Timing:
Net/Line
Routing Protocol:
Static
Port Base Rate (per Channel):
64K
Channels:
1-24
Edison Ortiz
You are correct. You must contact AT&T and have them verify the information once again. Perhaps the subnet mask is /29 instead of /30.
The only way to find out is by contacting them.
HTH,
__
Edison.
Edison Ortiz
HTH,
__
Edison.
Edison,
Thank you very much. It was AT&T's problem, as you stated. [Solved]
Jason
Jason
If Edison correctly identified the problem and pointed you toward the solution, it would be appropriate for you to use the rating system: mark the check box to indicate that your problem is resolved, and then mark points to indicate the correct solution. This helps people who are using the forum to identify posts that have led to the solution of problems.
[edit] Jason - thank you for following my suggestion.
Rick
Rick
