Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929446members
1243938discussions
Community Activity
How to communicate with 𝐋ufthansa 𝐀irlines?
How Do I Connect With 퐋ufthansa 퐀irlines?퓣퓸 퓬퓸퓷퓷퓮퓬퓽 with 퐋ufthansa 퐀퐢퐫퐥퐢퐧퐞퐬, explore multiple channels like their website, mobile app, or customer service hotline at+ퟭ-(ퟱퟳퟯ) ퟲퟬퟲ-ퟰퟱퟮퟬ (혜혚혈). Booking 헙헹헶헴헵혁s, managing reservations, and accessing travel...
Forward traffic from subnet to another on C3750
hi guys thanks for your suggestions in advancei just reconsidered my whole message. after trying some things. i think i need to set up acl but i'm far from good at it.what would be the ip access-list extended or access-list lines that'd allow me to h...
gabecz by Level 1
  • 145 Views
  • 3 replies
ATX録画と資料: SR-MPLS へのマイグレーション及び相互接続方法
本 Ask the Experts では、MPLS-LDP 網から SR-MPLS 網へのマイグレーション方法についてご説明します。また、新規構築した SR-MPLS 網と既存の MPLS-LDP 網の相互接続及び共存方法についてご紹介します。(英語タイトル:SR-MPLS interworking with MPLS-LDP)     Ask the Experts 録画と資料一覧はこちら
CISCO WSA upgrade alert error
We have upgraded our S1000v(wsa ) from 14.5.1 to 14.5.2 and upgrade was successful but when we checked the alerts we found an alerts as An application fault occurred: ('heimdall/svc.py send_command|195', "<class 'heimdall.exceptions.unknownprocess'="...
DK9 by Level 1
  • 36 Views
  • 1 replies
Resolved! Certificate install issue WLC DNA
For some reason one of our pair of WLC 9800 will not accept DNAC-CA certificate.A sync or push of telemetry from DNA fails. All our other devices are fine.If we try a CLI import of the certificate we get this:Trustpoint 'DNAC-CA' is a subordinate CA....
glsparks by Level 1
  • 421 Views
  • 6 replies
AP issue
Hello we have a local 9120axi AP with a 9800LC WLC that seems to be losing connection. The AP is in flex connect, all config looks fine: AdvancedCountry CodeUS  Multiple CountriesUSStatistics Timer180CAPWAP MTU1485AP Link LatencyEnabledAP PMK Propaga...
VPN route-based unable to ping remote IP
Hi, I am currently encountering issue on route-based ipsec vpn. I cannot ping my remote IP also the remote tunnel. I have verified that there is no decap showing on packets. I already configured static route between each site and still unsucessful of...
migrate policies from SMA
Is it possible to migrate policies and its dependencies alone from am SMA to another. Since both SMA are running different version backup restore is not working.
manvik by Level 3
  • 152 Views
  • 3 replies
ACI: Spine の N9K-C93600CD-GX の Eth1/1 の Counter が上がらない
2024年4月25日 (初版) TAC SR Collection主な問題 Spine として使用している N9K-C93600CD-GX の Ethernet1/1 を Leaf と接続して Up になりましたが、"show interface ethernet1/1" で Counter を確認しても全て 0 のままで増加しません。他の Port は問題無く動作しています。 Spine01# show interface ethernet 1/1 Ethernet1/1 is up a...
Re: odd loopback errdisable issue
Actually, I did post this in the Network/Switching forum.   I guess someone with power thought it was better suited here and moved it.  Which we both apparently disagree with.
Adding new switch to old stack
We have 2 SG350x-48 switches in a stack.  and we need to add another switch.  but I know that SG350x-48 is no longer sold.  what are my options?  these were replaced by the "Cisco Business 350 Series Managed Switches".  can one of these switches be a...
SCOTT No2 by Level 1
  • 100 Views
  • 2 replies
ASR9K:show policy-map interface にて Service Policy not installing となる
はじめに 本ドキュメントでは、ASR9000 シリーズルータにおける、シェーピング機能設定時における制限事項について紹介します。 概要 ASR9000 シリーズルータにおいて、以下のようなシェーピング機能を設定し、"show policy-map interface" にて統計情報を確認しようとした場合に、"Service Policy not installing" と表示され、シェーピングが機能しているログが確認できません。 [設定例] RP/0/RP0/CPU0:ASR9K#show r...
