NEC PBX Interaction with Cisco Call Manager
Oct 16th, 2008
We have a new building that we want to connect to our network and thinking of Callmanager to be installed and linking it to our NEC PBX.
Need some pointers on how am I going to go about doing that. Documents and examples will be really appreciated
Overall Rating: 3 (1 ratings)
testeven Fri, 10/17/2008 - 09:47
  • Cisco Employee,
Hi!
Here are some documents that might help:
*** NEC 2400 ICS PBX with CallManager using 3640-T1 MGCP Gateway ***
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_troubleshooting_guide09186a00808b6024.html
*** Cisco Unified CallManager Release 5.0-PBX Interoperability: NEC IPX2400 R15 to a Cisco CMM Using T1-PRI QSIG with MGCP ***
www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/522832nt.pdf
The second link includes info on SW and HW requirements as well as features supported.
*** Cisco Unified CallManager Release 5.0-PBX Interoperability ***
www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/248705nn.pdf
HTH, if it does please rate!
Tere :)
utawakevou Mon, 10/20/2008 - 13:57
Thank you very much. This really helps. Anyway our PBX is a NEC NEAX 2000 IVS2. Quite old :(
jpdenkiewicz Tue, 10/28/2008 - 06:23
Hi!
I have to connect CUCM 6.1 con NEC IPX2400 R22. I saw your link, but only talk about Release 15.
Is there a new link to understand how should connect to NEC PBX using Release 22? Thanks!!
