waridtel.com Thu, 10/16/2008 - 22:48
Thanks for the help. I am actually more concerned regarding the placement of IPS and in which mode I should configure IPS.
1. Promiscous.
2. Inline.
Best Regards,
Rahim
abinjola Fri, 10/17/2008 - 22:13
  • Cisco Employee,
See it depends on requirement...promiscous means in parallel to your network , which means the first packet would always go through the network/IDS and then IDS would start taking actions of consecutive packets..inline is blocking the very first packet..
see of this helps more..
http://www.cisco.com/en/US/docs/security/ips/5.1/configuration/guide/cli/cliInter.html
