inter vlan config between 3750 switch and 1721 router
Oct 16th, 2008
i have 4Mb lease line .2Mb is terminated to client and 2mb is server. then this line terminated to a 34 port unmanage switch and then 7 client by RF connectivity .how i can configure it so that 7 client access this server. kindly help me
Giuseppe Larosa Fri, 10/17/2008 - 03:48
Hello Arup,
it is not clear how the lease line is interconnected to the two LAN segments I imagine you have a router that does this job.
In this case you should be able to contact the servers from the clients if they have an IP address within router LAN interface's IP subnet.
You need two LAN interfaces because the switch is unmanaged.
Another possible solution is to connect all devices to the switch and to use IP address secondary on the router lan interface to accomodate the second IP subnet.
Because the switch is unmanaged we can suppose it is mono Vlan /single broadcast domain.
Hope to help
is66rlhntadm Fri, 10/17/2008 - 05:56
if the switch is unmanaged how can you any VLANs?
and in the title you say 3750 switch which is a managed switch
