ICM 7.2 RouterErrorCode 448
Oct 16th, 2008
I'm getting quite a few 448's in the customers RouterErrorCode.
It's mentioned in the Database Schema Handbook but I can't find any other references to it.
Any ideas what it is?
Many thanks.
BarryMcLellan72678 Mon, 10/20/2008 - 11:41
Try this:
Router Error Codes
Go to the ICM Admin Workstation folder.
Open Glossary
Click on ICM Master Help and then ICM Errors
Set the Category to "Call Router" and put in the error number that you are interested in
