CUCM 6.X or 7.0: Advice of Charge information displayedon the IP-Phone scre
Oct 17th, 2008
Hi!
Just a recurrent question to all related to the Advice of Charge information ... ;-)
Do you know if there is now the possibility to display the ISDN Advice of Charge information on the IP-Phone display during an outgoing call on the PSTN? This feature is every time asked from our customers in Switzerland and for years we are looking for a solution....
One of our current prospects has defined this feature as a mandatory requirement and we don't want to miss this interesting opportunity just because of this not supported Advice of Charge feature. Does one of you know a solution?
That's a trace of the information we are receiving from the ISDN
provider: we just need to display this ISDN "Display i = 'FR. 0.10'"
Facility information on the IP-Phone each time it has been updated from the provider. Could it be possible to use a TCL script or something similar?
*Oct 16 21:13:44.980: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 i
s 0x0 0x0, Calling num 216377627
s 0x0 0x0, Called num 0796323721
*Oct 16 21:13:44.980: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0015
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0081, '216377627'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '0796323721'
*Oct 16 21:13:45.052: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x
8015
*Oct 16 21:13:45.500: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x
8015
*Oct 16 21:13:49.880: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8
015
Progress Ind i = 0x8288 - In-band info or appropriate now available
*Oct 16 21:13:53.280: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x80
15
Date/Time i = 0x080A101628
Connected Number i = 0x00A3
*Oct 16 21:13:53.284: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref =
0x0015
*Oct 16 21:13:53.284: ISDN Se0/0/0:15 Q931: RX <- FACILITY pd = 8 callref = 0x8
015
Facility i =
0x91A11B02024E850201213012A10D810346522EA20681010A820101820
100
- ETSI Supplementary Service, Invoke, AOC-D Currency
*Oct 16 21:13:59.280: %ISDN-6-CONNECT: Interface Serial0/0/0:30 is now connected
to 0796323721
*Oct 16 21:14:18.268: ISDN Se0/0/0:15 Q931: RX <- INFORMATION pd = 8 callref =
0x8015
Display i = 'FR. 0.20'
*Oct 16 21:14:18.276: ISDN Se0/0/0:15 Q931: RX <- FACILITY pd = 8 callref = 0x8
015
Facility i =
0x91A11B02024E860201213012A10D810346522EA206810114820101820
100
*Oct 16 21:14:38.272: ISDN Se0/0/0:15 Q931: RX <- INFORMATION pd = 8 callref =
0x8015
Display i = 'FR. 0.30'
*Oct 16 21:14:38.276: ISDN Se0/0/0:15 Q931: RX <- FACILITY pd = 8 callref = 0x8
Many thanks in advance for much appreciated help
Kind Regards
Marco
mfasano Tue, 10/21/2008 - 01:11
Hey Tolga,
Many thanks for your answer. Yes I will use MGCP if this AOC feature is supported. But we tested it and only the first Facility Information announcement is displayed on the CP-79XX display but any other update is transmitted... As long as heard and read... this AOC feature is not supported by the CUCM and is not planned to be supported in the current development roadmap... I think that only European customers and integrators need it and unfortunately Europe is not the center of the world for Cisco UC Business Unit... :-(
If you have more details regarding roadmaps and the support of this feature, many thanks in advance to transmit them to me.
Kind Regards
Marco
