ASA - can the crypto map match address <acl> be found within ASDM?
Oct 17th, 2008
  • Bronze, 100 points or more
For instance:
crypto map TEST 10 match address TEST_ACL
access-list TEST_ACL; 2 elements
access-list TEST_ACL line 1 extended permit ip 192.168.1.0 255.255.255.0 172.16.1.0 255.255.255.0 (hitcnt=501)
access-list TEST_ACL line 2 extended permit icmp 192.168.1.0 255.255.255.0 172.16.1.0 255.255.255.0 (hitcnt=0)
I was trying to find this ACL in ASDM. There is an ACL in Configuration > Features > VPN > IPSec > IPSec Rules, but it is a different ACL entirely.
Check in the following location where you can find the access rules configured.
For ASDM 6.X:
Configuration->Firewall->AcessRules.You will be able to find all the Access-lists configured in this window.
ASDM 5.X:
Configuration > Features > Security Policy > Access Rules. You will be able to find all the Access-lists configured in this window.
