dependency records
Answered Question
Oct 17th, 2008
starting to feel like an idiot here, I'm trying to view dependency records, as i'm tryng to delete a CSS but its in use.
I've turned dependency on, but can't find where to view then, the help say's go to the related items box on the cucm config page and select dependency records. However I can't find this related items box anywhere, i'm obviously missing it, so can someone tell me where it is please, thanks
Grant
Correct Answer by Jaime Valencia about 8 years 9 months ago
go into the CSS, partition, whatever.
then, on the right hand just above the icons (new, delete, etc) and below the main menu there is a line. There is a dropdown menu there, usually it would say go back to find/list, go back to device page, depending on what you're looking for. just click on the drop-down menu, select dependency records and click the GO button
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Fri, 10/17/2008 - 03:06
  • Cisco Employee,
  • Hall of Fame,
    2011
java
reidg Fri, 10/17/2008 - 03:09
aarrgghh, new I'd saw it somewhere, thanks for that.
