pbr in Asa firewall version 8.0
Oct 17th, 2008
Hi Team,
local lan has the gateway as firewall inside ip. there is a 3750 L3 switch in between lan and firewall. now if we give the default gateway as firewall ip we [192.168.4.x] are unable to ping to 192.168.6.x network. But if we give the gateway as switch vlan ip [192.168.4.2] we are able to ping.
can we do some kind of routing/policy based routing in firewall with version 8.0
regards
Rajesh P
Farrukh Haroon Sat, 10/18/2008 - 23:19
  • Red, 2250 points or more
You just need to add a static route on the ASA
route 192.168.6.0 255.255.255.0
Then
same-security-traffic permit intra-interface.
If nat-control is enabled, then you need to add NAT as well.
Farrukh
