IOS COMPABILITY WITH HARDWARE
Oct 17th, 2008
HI ALL
i HAVE 2600 Router with flash c2600-i-mz.122-15.T11.bin and unused ethernet module NM-1E.
I want to move this NM-1 E to another 2610 XM router, i know that this NM-1E module is also supported in
2610 XM, but i am planning to upgrade the IOS to c2600-advipservicesk9-mz.123-26.bin in 2610 XM rouer
My question is this IOS supports NM-1E, please let me know how to check IOS comatability with Hardware
thanks Adhi
Giuseppe Larosa Fri, 10/17/2008 - 05:43
Hello Adhi,
there is a Cisco tool called software advisor that can be used for this type of check
http://tools.cisco.com/Support/Fusion/FusionHome.do
you may need more then guest CCO account
choice find software compatible with my HW
then select config manually specify router c2600 model c2610XM
However, the answer is yes it is supported
Hope to help
Giuseppe
