is66rlhntadm Fri, 10/17/2008 - 08:16
any help would be welcomed
it crashed while I was correcting the config (just swapped it into the place of a 2651 and was turning on interfaces I had shutdown and ensureing proper config)
is66rlhntadm Sat, 10/18/2008 - 15:28
since the aim1 light has been amber I figured it might be the problem so I swaped it for another one
but the light is still amber
is there something I need to do to enable it or something?
Mark Yeates Sat, 10/18/2008 - 17:28
Richard,
Looking at your crash file this is the log error that caused the crash.
%ALIGN-1-FATAL: Illegal access to a low address 19:02:20 -0500 Thu Oct 16 2008
addr=0x8, pc=0x63531608 , ra=0x635315F4 , sp=0x68936BE8
%ALIGN-1-FATAL: Illegal access to a low address 19:02:21 -0500 Thu Oct 16 2008
Here is the output from the Error Message Decoder:
An alignment error has occurred. Alignment errors are caused by misaligned reads and writes. For example, a two-byte read of a memory address that is not a multiple of two bytes is an alignment error. Alignment errors are c aused by internal software failures. The system will be reloaded, often with a bus error.
Recommended Action: This message is caused by a software failure. To take advantage of recent fixes, upgrade your system to the latest Cisco IOS software release in your release train. If this message recurs, copy the error message text exactly as it appears on the console or in the system log, enter the show log, show alignment and show tech-support commands, contact your Cisco technical support representative, and provide the representative with the gathered information.
HTH,
Mark
