Authenticating CA on a Cisco Router 880
hgbragman
Hi! I'm trying to auth my CA from my 880 cisco router, but get this message:
"% Do you accept this certificate? [yes/no]: yes
Trustpoint CA certificate accepted.
%PKI-3-UNUSABLE_KEY_USAGE: Key-usage type 'Certificate-Signing' for cert with serial number 65 is not usable."
I understand that the router maybe wants the KeyEncipherment, but how can this be? CertificateSigning is what a CA is for, isn't it?
Not applicable
The error message says that the given key-usage type is not usable by IOS. If seen during an import operation, this will likely cause the import to fail. Acceptable key-usage types should include Key-encipherment and/or digital-signature. Other key-usage types may be present, but will be ignored.
Recommended Action: Recreate the certificate with key-encipherment, digital-signature, or both.
The below URL helps you to configure certificates on IPsec devices:
http://www.cisco.com/en/US/docs/ios/11_3/feature/guide/interop.html#wp5370
To install and authenticate the CA certificates associated with a trustpoint, use the crypto ca authenticate command in global configuration mode.
Refer the below URL for more information:
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/c5_72.html#wp2062259
