transfer to voicemail
Oct 17th, 2008
Hi all, Im trying to figure out the sequence for an operator to transfer a call directly to voicemail. This is on a CUCM 6.1. Any help would be appreciated.
Overall Rating: 4.4 (5 ratings)
Jaime Valencia Fri, 10/17/2008 - 05:02
  • Cisco Employee,
  • Hall of Fame,
    2011
this should get you on track
Transfer a Caller Directly into a Unity Express Mailbox
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a00802ab979.shtml
How to Transfer a Caller Directly into a Cisco Unity Mailbox
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a008015b963.shtml
java
if this helps, please rate
Rob Huffman Fri, 10/17/2008 - 05:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi John,
Hope all is well!
Just to add a note to the good tips from Java (+5 points for you my friend for your Friday AM coffee :) Have a look at the attached doc;
Hope this helps!
Rob
jjoseph01 Fri, 10/17/2008 - 08:12
Thanks to both of you. I actually did this as just trying to "wing" something and it appears to work. Im glad to know about the pdf though. Thank you both. I apprecaite all your help.
jjoseph01 Fri, 10/17/2008 - 08:14
Oh, and the first one is the one Ive always done Java. But for some reason, it only worked on about half the phones at this location. Not sure why, thats when I went to plan "dont know what to do but wing it" B.
