802.1x Profile Issue
Oct 17th, 2008
we are using 802.1x Peap mschap v2.
Whenever our users log into their computers they can't use the wireless. It prompts for username/password and domain and typing it in won't work, it just keeps asking
but when i ahev them sign into the domain in the wired network and then try, they can login just fine
could there be an issue where the domain controller doesn't have a profile created?
Scott Fella Fri, 10/17/2008 - 18:10
What does the radius server log show. Also, what error do you see on the WLC?
thompso7540 Mon, 10/20/2008 - 09:36
So they are logging in with laptops not on the domain, and it prompt that local user/pass checkbox
is that a problem if we are doing radius into ldap?
Like they have a domain account but are not on a laptop on the domain
Scott Fella Mon, 10/20/2008 - 17:07
The prompt is specified when you create the profile on the machine. You can either have the user get prompt for login, save a username and password or use the cache credentials. You need to look at the errors in radius and in the wlc. One will have enough info to say what went wrong during the authentication process.
thompso7540 Mon, 10/20/2008 - 17:19
Here are the debugs from teh wlc. when i uncheck peap - don't automatically use windows login with windows wireless zero; it lets me type in the domain name and i am able to get it to work
Scott Fella Mon, 10/20/2008 - 17:25
So it works when you type the domain\username and then the password. Have you tried to uncheck the "Authenticate as computer when computer information is available"? I do think you need to specify the domain though.
thompso7540 Mon, 10/20/2008 - 17:37
the acs says this
EAP-TLS or PEAP authentication failed during SSL handshake
Scott Fella Mon, 10/20/2008 - 17:44
Make sure you uncheck "Validate Server Certificate", unless you add the CA to the trusted certificate store.
Trending Topics - Security & Network
