No SPI to identify Phase 2 SA
Oct 17th, 2008
I have configured several tunnels on an ASA 5510. But I am trying unsuccessfully to configure another one.
This particular tunnel is completing Phase 1 successfully, but then I get the error
"No SPI to identify Phase 2 SA".
I have scoured the internet and the responses I have seen say to check to make sure both ends have the same subnet and to make sure that PFS matches on both ends.
I have gone over and over the configs and cannot find any problems.
Anyone have any ideas?
singhsaju Fri, 10/17/2008 - 08:19
  • Silver, 250 points or more
Can you post configs from both sides for us?
Also try disabling PFS from both sides and let the VPN tunnel come up with basic settings . You can add PFS later once tunnel is up.
Also post complete debugs from both sides .
Saju
Pls rate helpful posts
