LMS 3.0.1 / RME : unable to subscribe syslog collector
Oct 17th, 2008
Customer has LMS 3.0.1. syslog reports are empty.
When we look at RME->tools->syslog->collector status:
all colums are N/A except Name: LMS hostname and Update time : Not Reachable.
Both SyslogCollector and SyslogAnalysor are running:
Process= SyslogAnalyzer
State = Program started - No mgt msgs received
Pid = 9576
RC = 0
Signo = 0
Start = 03/10/2008 12:16:01
Stop = Not applicable
Core = Not applicable
Info = Server started by admin request
Process= SyslogCollector
Pid = 19616
RC = 0
Signo = 0
Start = 03/10/2008 12:13:58
We have verified that LMS server received syslog with a sniffer.
We unsubscribe collector, after we try to subcribe, but it fails with this message:
SLCA0126: Could not subscribe to the Collector.
1.Check whether the collector is running.
2.Make sure that SSL certificates are imported/exported correctly and process restarted.
3.Check whether the Certificates exported/imported are valid and have not expired.
4.Check whether SyslogAnalyzer process is running.
Thanks, Elisabeth
Here, you can find logs with debug.
Joe Clarke Fri, 10/17/2008 - 07:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Two problems I see. One, the server appears to be localized for French which is not supported. You must change the server's localization to US English. Second, it appears another application is occupying tcp/4444. If you shutdown Daemon Manager, and look at netstat -a -n -o -b, you can see what application this is. If that application is shutdown, and Daemon Manager is restarted, syslog analysis should begin to work.
ebezombes Mon, 10/20/2008 - 04:22
Hi Joe,
Many thanks for your response, port 4444 was not available ! Best regards, Elisabeth
mohamedtwair Wed, 02/25/2009 - 05:41
hi ebezombes,
i am facing the same problem excatly
port 4444 is not available,what did you do after that?
thanks in advance
regards
Joe Clarke Wed, 02/25/2009 - 10:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Your two choices are either to free up tcp/4444 on the server so that SyslogAnalyzer can use it, or change the value on NMSROOT/MDC/etc/regdaemon.xml. Replace 4444 with another free TCP port value. Make sure you backup regdaemon.xml before making any changes.
After making the change, restart Daemon Manager.
mohamedtwair Sun, 03/01/2009 - 02:33
hi again
i replaced 4444 with 48889 TCP port(NMSROOT/MDC/etc/regdaemon.xml) but still facing the same problem
do you have any other options?
regards
Joe Clarke Sun, 03/01/2009 - 09:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You should start a new thread for your issue.
mohamedtwair Sun, 03/01/2009 - 22:49
Thanks for your response but i have one more questions,after changing the ports,i followed the following path:C:/PROGRA~2/CSCOpx\MDC\tomcat\webapps\rme\WEB-INF\classes\C:\PROGRA~2\CSCOpx\MDC\tomcat\webapps\rme\WEB-INF\classes\com\cisco\nm\rmeng\csc\data
\Collector.properties"
and i noticed that the COLLECTOR_PORT=4444
do u think i need to change this too?
i have another cusotmer with same configurations but the syslog is working just fine.
regards
Joe Clarke Mon, 03/02/2009 - 07:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, this port must be changed, too, to match the port in regdaemon.xml.
