interface Group-Async0
Answered Question
Oct 17th, 2008
Looking at my Config File (GW 5400), I found:
ip unnumbered FastEthernet0/0
encapsulation ppp
ip tcp header-compression
no ip mroute-cache
async mode interactive
peer default ip address pool dialin_pool
ppp max-bad-auth 2
ppp authentication pap chap
group-range 1/00 3/107
I dont know why this is configured on the GW. What is this interface?
Thanks in advance.
Correct Answer by testeven about 8 years 5 months ago
Hi!
The interface Group-Async0 is used for example, for modems. Sometimes the AS5400 can be configured to accept calls from both Async and ISDN users and that's when you use this type of config.
You can check this link:
http://www.cisco.com/en/US/products/hw/univgate/ps505/products_configuration_example09186a0080094a49.shtml
Hope this answers your question, if so, please rate!
Tere :)
Overall Rating: 5 (1 ratings)
Correct Answer
testeven Fri, 10/17/2008 - 09:32
  • Cisco Employee,
Hi!
Tere :)
guillermohurtado Fri, 10/17/2008 - 10:43
Thanks that was very useful.
Now, I want to erase all the async interface at once, how can I accomplish this?
Thanks.
testeven Fri, 10/17/2008 - 11:46
  • Cisco Employee,
The Async interfaces are virtual and they can be associated with a physical modem just as you have done with the
group range command. The Asyn0 is created by default. I will not recommend to delete the interface group-async 0,
because all the async interfaces in a brand new box should be grouped under "group-async0". That's the whole purpose of
group-async 0.
But for the other interfaces that you are not using you can do a "no interface group-asyncX". Sometimes whe you delete the
"0" there are a bunch of interfaces created one for each modem. To avoid this you should use the group range command to
associate them with one interface only and delete the rest.
Tere.
