Manoj Wadhwa Fri, 10/17/2008 - 08:26
Hi Jamal,
Can you advice the exact IOS for any other model (1700, 2600, 3700, 7200 ). I am trying to find using the link you provided but if you already know the exact version as per your experience, it will be helpful. Thanks again.
Manoj
jamalbelarj Fri, 10/17/2008 - 10:22
for 3725:
Software Image (Latest Maintenance Release in Train):
c3725-advipservicesk9-mz.12.4-6.XT2
Thanks.
Giuseppe Larosa Sat, 10/18/2008 - 03:54
  • Hall of Fame,
    Founding Member
Hello Manoj,
C3640 is fine for MPLS I'm afraid C3620 doesn't support it
a good platform is C2600XM and there is difference with normal c2600.
C3700 and C7200 are really good for this.
Hope to help
Giuseppe
