Change 1130AG LAP network settings remotely
Oct 17th, 2008
I have a 1130AG LAP that i upgraded to LWAPP. I chose to keep the static IP of the access point. I suspect that during the upgrade process the access point was not set with the IP address of the WLC.
Is there any way that I can remotely change the access point's network settings? It has to be done remotely because the access point ins in an inaccessible location
Thanks in advance for any help forwarded.
Victor
dennischolmes Fri, 10/17/2008 - 09:22
  • Gold, 750 points or more
Is the AP on the same LAN segment? If it is it should discover the WLC in its LWAPP discovery process. If not, you will need to prime the AP with the controller address.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
