Warning message
AD Schema Update
Oct 17th, 2008
In a Unity 5.1 installation with Exchange 2003 w/failover environment I have been told that I do not need to do an AD Schem update when an Exchange 2007 mailstore come online, just run the permissions wizard. Can anyone confirm that?
Thanks in advance! All replies rated
Overall Rating: 4 (3 ratings)
Bradford Magnani Fri, 10/17/2008 - 09:46
  • Cisco Employee,
The schema update is for the Unity software. When you install Exchange it goes through and does its own thing to the directory with domain prep and forest prep. If it's been run once already, you shouldn't need to run it again. Someone may want to back me up on this one.
Brad
Jaime Valencia Fri, 10/17/2008 - 10:27
  • Cisco Employee,
  • Hall of Fame,
    2011
just to add some info, the AD schema only adds properties, previous properties other versions applied remain and is still backwards compatible
java
if this helps, please rate
angel-moon Fri, 10/17/2008 - 11:48
ok. So am I hearing that since we are not upgrading Unity and are just bringing on an Exchange 2007 mailstore that we don't need to run it?
ranpierce Fri, 10/17/2008 - 11:52
  • Silver, 250 points or more
If you are upgrading Exchange you might need to do the exchange schema but no the Unity only needs the Unity schema updates when you upgrade Unity.
Randy
