firewall verson
Oct 17th, 2008
how can I know the detail version of the firewall. such as 7.2(4)7. sh version only told me it is 7.2(4)
carsonhee Fri, 10/17/2008 - 10:39
Thanks, still got 7.24
Directory of flash:/
6 -rw- 8515584 20:14:04 Oct 07 2008 asa724-k8.bin
ajagadee Fri, 10/17/2008 - 12:09
Hello Kai,
Based on the above outputs, you are running 7.2(4) version of the ASA Software.
7.2(4)7 basically is an interim version.
Are you looking for a specific bug that if fixed in 7.2(4)7 or are you looking for the fix in the below Security Advisory.
Anyways, you can download the interim version of the ASA Software from the below URL:
In the above URL you can see that there is an interim image available in the 7.2 train, which is 7.2(4)9
I hope it helps.
** Please rate all helpful posts **
