Media player....
Oct 17th, 2008
I cann hear voicemail messages in Windows Media Player, I can hear mp3's but i cannot hear voicemails. I went into the OLK file and deleted all the vociemail "files" thinking that might do the trick, but it did not. I also tried reinstalling MP, but that didnt work either.
Any thoughts?
-James
ranpierce Fri, 10/17/2008 - 11:27
  • Silver, 250 points or more
Not sure what you mean? What is the difference between voicemail messages and voicemail?
Randy
ranpierce Fri, 10/17/2008 - 11:49
J so you say you can hear and you can't hear.
Need help understanding. I have tested and it is working on my machine.
Randy
omgjames1 Fri, 10/17/2008 - 11:56
cannot hear voicemail messages in Windows Media Player, I can hear mp3's but i cannot hear voicemails messages. I went into the OLK file and deleted all the vociemail "files" thinking that might do the trick, but it did not. I also tried reinstalling MP, but that didnt work either.
testeven Fri, 10/17/2008 - 12:47
  • Cisco Employee,
Make sure you can play .wav files with the WMP also check the codec you are using, probably you are using G.729 for the messages and your Media Player does not support it unless you install it.
testeven Fri, 10/17/2008 - 12:50
  • Cisco Employee,
What I mean is that Windows Media Player does not come with the G.729 codec by default which is probably why you can not listen to the Wav files using Windows Media Player, but you can using the IP phone. Cisco IP phones support both G.711 and G.729 Codecs.
Check this link for more info about WMP and codecs:
http://www.microsoft.com/windows/windowsmedia/player/faq/codec.mspx
omgjames1 Sun, 10/19/2008 - 15:46
all 124 users can hear it through Windows media player though, ill give it a shot and let you guys know.
-J
