How to Prevent Single point Fail-over on LAN Swicth 3750
Oct 17th, 2008
Can someone please advice or informe me on what technology or how to prevent fail-Over on Catalyst Switch 3750 used at distribution layer (Router on Stick) for VLAN in the Topology. I had HSRP already at Core Layer.
R1 R2
\(HSRP)/
SW
FW-------DMZ
SW (3750)
SW1 SW2 SW3>(LAN 2950G)
Overall Rating: 3.7 (3 ratings)
Davy Ad Sat, 10/18/2008 - 01:50
I hope this will not make you feel that i am disturbing you Could you please send me the link to do this or explaine.Thanks a Lot
In the primary 3750:-
interface vlan xx
ip address y.y.y.y z.z.z.z
standby vv ip address w.w.w.w
standby vv timers 1 3
standby vv priority 240
standby vv preempt
ip route 0.0.0.0 0.0.0.0 <>
In the secondary 3750:-
interface vlan xx
ip address t.t.t.t u.u.u.u
standby vv priority 200
standby vv preempt
Also make the primary 3750 the spanningtree root. connect backup connections to the
secondary 3750 and configure as the alternate spanningtree root.
spanning-tree vlan 1-1024 root primary
spanning-tree vlan 1-1024 root secondary
xx = vlan number
y.y.y.y = ip address , i.e 192.168.1.253
z.z.z.z = subnet mask, i.e 255.255.255.0
vv = vlan number
w.w.w.w = standby ip address, i.e 192.168.1.254
t.t.t.t = ip address, i.e 192.168.1.252
u.u.u.u = subnet mask, i.e 255.255.255.0
w.w.w.w = stnadby ip address, i.e 192.168.1.254
HTH>
Davy Ad Sat, 10/18/2008 - 03:24
Appreciate ! More Grace and knowledge to You
DAK
Davy Ad Mon, 10/20/2008 - 04:11
Once again would it be better ,if i use only Switch Stack method for the two 3750 instead of HSRP?
