1720 router serial bandwidth usage command
Oct 17th, 2008
I have a cisco 1720 router runing ver 12.1(2) it is at a remote site on the end of a t-1.. I want to see bandwidth type usage but dont know the command to give so i can see that.
spremkumar Sat, 10/18/2008 - 00:19
hi
you can make use of show interface serial x/x to view the byte counters which gives you a fair idea about the utilisation of the links.
regds
ganeshhiyer Sat, 10/18/2008 - 01:51
Check with show interface serial command to check the bandwidth in bytes.
Ganesh.H
