switch redundancy and router redundancy and Vlan
join_sn09
Dear All,
i would like redundancy switch and router and vlan.
Coudl you advice configuration or documents?
Best Regards,
andrew.prince
Level 10
Level 10
See the attached. Just a suggestion.
Dear Andrew,
Thank you for your advice,, :)
so on your diagram that you gave me it don't have router link to branch.I would like link branch to HQ by lease line then i have to at one more router on HQ, could you check for me again my diagram that i was post last time.
Oh could you give me configuration for etherchannel ? and more configuration on my diagram?
Thanks for you help :)
Best Regards,
Join
OK - from the diagram that was not clear.
Are you running any dynamic routing protocol, or do you just have static routes?
The etherchannel config would look something like:-
Switch 1 config:-
interface Port-channelxx
description *** EtherChannel switch 2 ***
switchport
switchport mode trunk
no ip address
interface Gig0/1
description *** Switch 2 etherchannel ***
switchport
no ip address
channel-group 50 mode desirable
interface Gig0/2
switchport
no ip address
Switch 2 config:-
description *** EtherChannel switch 1 ***
switchport
no ip address
interface Gig0/1
description *** Switch 1 etherchannel ***
switchport
no ip address
interface Gig0/2
switchport
no ip address
HTH>
