2960 Model Sw with Part no: WS-C2960-24TC-L has an error.....
Oct 17th, 2008
Dear All,
I have configured and installed one 2960 Switch part no WS-C2960-24TC-L with GLC-FE-100FX SFP module for MM fiber cable and 2912XL SW on other end.
Now Switch is working fine but continuosly sending log of duplex mismatch. I can not set duples or speed on this port ( port with this SFP module.
So pls suggest me the work around
Dipesh.
ganeshhiyer Fri, 10/17/2008 - 23:00
Hi Dipesh,
You cannot set duplex setting in SFP ports,try to configure nonnegotiate on both the end of the SFP.
Ganesh.H
Dipesh Patel Mon, 10/20/2008 - 00:37
dear Ganesh,
Oct 20 13:32:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
hernet0/1 (not full duplex), with NG32912 FastEthernet0/8 (full duplex).
Oct 20 13:33:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:34:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:35:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:36:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:37:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:38:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:39:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:40:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:41:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:42:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:43:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:44:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:45:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:46:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:47:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:48:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:49:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:50:18: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:51:19: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:52:19: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
Oct 20 13:53:19: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEt
At Oct 20 13:50:20 , I have configured as below on 2960 and on 2912 there is no option.
interface GigabitEthernet0/1
switchport trunk allowed vlan 1,29
switchport mode trunk
switchport nonegotiate
udld port aggressive
end
but than also yet the same logs continue ......
You can see in logs after 13:50 .....
pls suggest me what to do now.
Dipesh
