L2TP - PPP IPCP failure
Oct 17th, 2008
I am in the process of building a broadband solution where the telco owns the LAC/LTS infrastrucutre and I own the LNS. The sites are using ADSLoPSTN and run PPPoA to a dialer i/face. The LNS is a 7201 running 12.4-15.T6, the remote is 12.4-17b AdvIPServices
I have an issue where the remote site is not entering the ip address of the LNS into its routing table as a host route, nor does it appear in show users.
The IP Address at the site is being delivered successfully by radius and everything works, but I need the host route for other reasons.
An erronous line of code had been entered at the remote site router config templates:
ip address-pool local
This breaks IPCP - not terminally but just enough to prevent the host route being installed.
