Operational status goes down on dot11radio interface
Oct 18th, 2008
Hi all,
I need help solving the following problem…
I have 8 LAP-1231-E-K9 and 4402 WLC connected onto a network. The controller found the AP's. But it brings the Dot11Radio interface operational status to DOWN on every restart on the WLC or the LAP.
Here is the output that I get from the LAP on startup:
flashfs[0]: 11 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 5178880
flashfs[0]: Bytes available: 2562560
flashfs[0]: flashfs fsck took 13 seconds.
Reading cookie from flash parameter block...done.
Base ethernet MAC Address: XXX
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1200-k9w8-mx.124-3g.JA/c1200-k9w8-mx.124-3g.JA"...#####
File "flash:/c1200-k9w8-mx.124-3g.JA/c1200-k9w8-mx.124-3g.JA" uncompressed and installed, entry point: 0x3000
executing...
*Mar 1 00:00:04.466: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar 1 00:00:05.664: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar 1 00:00:06.834: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1200 Software (C1200-K9W8-M), Version 12.4(3g)JA, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 27-Apr-07 02:03 by pwade
*Mar 1 00:00:06.850: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:00:06.859: %DOT11-6-FREQ_SCAN: Interface Dot11Radio0, Scanning frequencies for 32 seconds
*Mar 1 00:00:07.692: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 00:00:07.850: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar 1 00:00:08.692: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar 1 00:00:25.848: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar 1 00:00:25.848: bsnInitRcbSlot: slot 1 has NO radio
*Mar 1 00:00:25.875: bsnUnlockDevice: not bring radio up: radio 1 is in admin disable state
*Mar 1 00:00:26.122: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:00:26.539: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:00:26.550: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:00:26.556: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:00:26.566: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:00:27.550: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar 1 00:00:34.999: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.245.72.112, mask 255.255.255.0, hostname AP-08-03
Translating "CISCO-LWAPP-CONTROLLER.DOMAIN.COM"...domain server (10.245.20.10) [OK]
*Mar 1 00:00:50.541: LWAPP_CLIENT_ERROR_DEBUG: spamHandleDiscoveryTimer : Found the discovery response from MASTER Mwar
*Mar 1 00:00:50.557: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*Mar 1 00:00:50.559: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar 1 00:00:51.559: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Oct 16 14:34:41.707: %LWAPP-5-CHANGED: LWAPP changed state to CFG
*Oct 16 14:34:41.755: %LWAPP-5-CHANGED: LWAPP changed state to DOWN
*Oct 16 14:36:56.000: %LWAPP-5-CHANGED: LWAPP changed state to UP
*Oct 16 14:36:56.063: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
The LAP is running the following software:
S/W Version - 4.1.171.0
Boot Version - 12.3.2.4
IOS Version - 12.4(3g)JA
and the WLC:
Hope to hear soon from one of you…
Thanks in advance
Scott Fella Sat, 10/18/2008 - 10:16
That is normal.... but only if the radios come up after you see the "LWAPP change state to up".
Plasiboli Sun, 10/19/2008 - 22:29
Well the thing is that it does not come up after that, it is still down...
