policy based routing question!!!!*****!!!!!(*-*)
Answered Question
Oct 18th, 2008
Hi all,
I configured this route-map my question is
if i add other next-hop in same statement like (f.f.f.f) how Mr.router-map will deal with it
route-map blabla permit 10
match ip address 110
set ip next-hop x.x.x.x f.f.f.f
X.X.X.X first IP
f.f.f.f second IP that i will configured it
Correct Answer by Jon Marshall about 8 years 8 months ago
Yes you can do this. The router will used x.x.x.x as the next hop. If that is unavailable it will use f.f.f.f.
Jon
Overall Rating: 4 (1 ratings)
Correct Answer
Jon Marshall Sat, 10/18/2008 - 05:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
yahoo2006 Sun, 10/19/2008 - 06:24
I thought that will make load balancing between two IPs
