Voice vlan and thins clients
Oct 18th, 2008
I've a catalyst 3560 (gbit/poe) switch with a voice enabled router 2851.
At the switch and router i've 3 vlans 1(native), 100(voice), 200(video). I also have an 7941 ip phone with a HP thins client attached. I'm using the smartport to setup the ports. As long as I'm using vlan 1 everything is working. When I set my access vlan to 1 and my voice vlan to 100 the thin client is losing the connection after aprox 10 second of no activity. When I keep working the connection is maintained. Any thoughts
Thx
Filip
Amit Singh Sat, 10/18/2008 - 06:24
Filip,
Please paste the switch configuration. You mean that thin client HP pC doesnot lose the connection when you are idle on Vlan 1. if it looses the connection then after what period ?
