Urgent - upgrade DRAM
Oct 18th, 2008
I am in the process of upgrading the RAM on a at Cat 6509. I have replaed the DRAM as instructed but doing show version still shows the same old value
I am upgrading from 128M to 512M. I need it to be 512M so that it can take a new card
cisco WS-C6509 (R7000) processor (revision 3.0) with 112640K/18432K bytes of memory.
Processor board ID SAL0720D9PF
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
1 Virtual Ethernet/IEEE 802.3 interface(s)
288 FastEthernet/IEEE 802.3 interface(s)
4 Gigabit Ethernet/IEEE 802.3 interface(s)
381K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
Standby is up
Standby has 112640K/18432K bytes of memory.
Where should it show the 512M?
