Timeout Delay
Oct 18th, 2008
Guys,
I need your expertise, the end-user is complaining for a big delay to thier IP phone whenever dialling any outbound calls before it connected. Is there any quick solution to rectify this issue. We tried to put a # sign at the last after dialling the number but the delay is still the same.
Any output is really appreciated.
Overall Rating: 5 (1 ratings)
Jaime Valencia Sat, 10/18/2008 - 09:31
  • Cisco Employee,
  • Hall of Fame,
    2011
most probably you have interdigit timeout due to dial plan overlapping, if you do not add the # to the route pattern (unless using @) it won't work. only @ recognizes it automatically, any pattern that does not contain @ needs the # in the pattern
review your dial plan and take out whatever overlapping you have to fix this
use route plan report for this purpose
java
if this helps, please rate
JUNKSA_2 Sat, 10/18/2008 - 11:12
Hi, Thanks for the info. Follow-up Question,
can I make a single route pattern for the following route pattern?
International:
0.00xxxxxxxxxxxx
0.00xxxxxxxxxx
0.00xxxxxxxxxxx
Thanks again
Jaime Valencia Sun, 10/19/2008 - 10:01
  • Cisco Employee,
  • Hall of Fame,
    2011
0.00xxxxxxxxxxxx
any way you're going to have IDT if not dialing all the digits
leave the 3 route patterns and add #, you'll have to educate users to dial # after the numbers. this happens to all deploys since CUCM has no idea how many digits an international call needs and will wait for the IDT or the #
even using 9.@ or 9.011! has the same issue
java
