Supervisor card status light - urgent
Oct 18th, 2008
t
i have just reinserted a standby supervisor card into a cat 6509 after upgrading the RAMfromn 128 to 51M2 and the status light keeps going from green to red. help. Its not being recognised under show module
What do i do?
Edison Ortiz Sat, 10/18/2008 - 10:23
  • Hall of Fame,
    Founding Member
It seems you've missed a step or you have wrong/faulty memory. It's hard to troubleshoot this urgent matters online, why not calling Cisco TAC?
__
Edison.
qwertys21 Sat, 10/18/2008 - 10:48
Thaanks Edison
They are new ones. I put them in at first and they were still reading 128M but it came back up alright which is strange as they are 512M RAM. So i removed it and reinserted it properly and now I have the status and power mgmt light going from green to red and then to green continuosly, do u think the RAM has been damaged? Can the sup card be damaged already as I have to remove it twice?
Its been doig this now for 30mins
Pls help.
jacobuecker Sat, 10/18/2008 - 10:56
Can you remove the RAM and make sure it still functions normally in it's original condition?
jacobuecker Sat, 10/18/2008 - 11:41
If it's doing the same thing when you put everything back in it's original state, it could me a couple of things. First are you absolutely sure that everything is seated properly, fully inserted, etc? Assuming it is, something may have happened to the board which is causing it to malfunction. I would really suggest opening a TAC case.
qwertys21 Sat, 10/18/2008 - 13:43
Thanks. I have. I have a spare sup card. Do i just place it in and it will download d config from the active?
jacobuecker Sat, 10/18/2008 - 16:07
Yes I believe it will. Make sure you have your active runnning configuration saved however, just in case.
