Installing Unity ?
Oct 18th, 2008
How the unity is installing? Is it installed after installing windows server or should we put the unity dvd and it will install all of them both windows and the unity itself?
Any installation guide?
thanks
Md. Mijanur Rahman Sat, 10/18/2008 - 22:09
  • Silver, 250 points or more
First, you will need windows 2000 AS, or Windows server 2003
Second, you will need active directory installed, create a user for unity with permissions with Enterprize admin, schema admin, domain admin, local admin and login with the user
Third, you will need MS Exchange server installed (exchange 2003 for unity v.4.2 or lower, exchange 2007 or 2003 for unity 5.0 and higher)
Then follow installing unity from unity installer, you will need some microsoft patches, you will get guided while started installing and download from net.
HTH.
Please rate if helpful.
tim.giles Sun, 10/19/2008 - 07:22
It depends on whether you are integrating with Exchange or Lotus Domino and whether you are building it for Unified messaging or voicemail only. You may also need to consider Unity failover configuration.
I've attached a link to all the installation guides for all versions:
http://www.cisco.biz/en/US/products/sw/voicesw/ps2237/prod_installation_guides_list.html
Please rate useful posts...
