Problems with Tunnel from pix A to pix B
Oct 18th, 2008
VPN Parameters
pix B end point is 66.66.66.66
pix B network is 192.168.50.0/24
pix A will need to make ACL from 172.24.176.9 to host 192.168.50.83 and 192.168.50.86
pix A will need to NAT intresting traffic to 172.24.176.0 /24
pix A
Phase 1
Authentication: Pre-Shared
Encryption: 3DES
Hash: SHA
DH: 1
Lifetime: 86400 sec
Phase 2
ESP encryption 3DES
ESP authentication
Lifetime 28800
pix A
outside 12.12.12.12 /24
insdie 192.168.1.2 /24
Problem creating tunnel from pix A to pix B
c-drozd Sun, 10/19/2008 - 06:19
I beleive my problem is configuring the ACL properly. If I am correct if the ACL is correctly configured then a tunnel can not be created?
c-drozd Sun, 10/19/2008 - 07:54
Reposting message because of typo. I beleive my problem is configuring the ACL properly. If I am correct if the ACL is not correctly configured then a tunnel can not be created?
ajagadee Wed, 10/22/2008 - 16:34
  • Cisco Employee,
Yes, are correct. ACL is what defines the interesting traffic for IPSEC and that is what triggers your IPSEC L2L Tunnel.
Can you post the Pix configuration along with the outputs of "deb cry is" and "deb cry ips".
Arul
*Pls rate if it helps*
