Read/Get SNMP from Cisco phones
Oct 18th, 2008
Is there a way to read/get snmp information from cisco phones? I have snmp enabled on the call manager and subscriber, but can't find a way to read snmp info from the phones. Is that possible? Thanks.
manjithkumar1972 Mon, 07/25/2011 - 02:43
The following is configuration to be done for getting the SNMP traps for Phones, as per CUCM manual:
Configuring CISCO-CCM-MIB Trap Parameters
Unified CM and Unified CM BE only:
Use these guidelines to configure CISCO-CCM-MIB trap settings on your system:
Set ccmPhoneFailedAlarmInterval (1.3.6.1.4.1. 9.9.156.1.9.2 to a value in the range 30-3600 by using the SNMP Set operation; for example, use the net-snmp set utility to set this OID value from the linux command line using: snmpset -c
-v2c
1.3.6.1.4.1.9.9.156.1.9.2 .0 i
You can also use any other SNMP management application for the SNMP Set operation.
Set ccmPhoneStatusUpdateAlarmInterval (1.3.6.1.4.1.9.9.156.1.9.4) to a value in the range 30-3600 by using the SNMP Set operation; for example, use the net-snmp set utility to set this OID value from the linux command line using:
snmpset -c
-v2c
1.3.6.1.4.1.9.9.156.1.9.4.0 i
But can someone help me in getting the Linux CLI prompt in CUCM, as these commands are to given on Linux CLI, or is there a mistake in my understanding.
