Urgent !!!
Oct 18th, 2008
Dear Netpros,
Below is the urgent requirement from the customer. Pl help me to figure out the vpn product from cisco.
if the 5500 can't do transparent mode VPN. Can you suggest something that is capable of high speed, 100Mbps VPN. I'd prefer a router if possible that is capable of this.
I don't mean one that Cisco says can do 100Mbps, they base their figures on specific variables. I would like one that in the real world is capable of 100Mbps full duplex.
sami
Farrukh Haroon Sun, 10/19/2008 - 22:45
Cisco does not support VPNs in transparent mode :).
Only 'to-the-box' management VPNs are supported in L2 mode.
Farrukh
