WS-SUP720-3B - 2 Ten Gigabit Interfaces
Answered Question
Oct 19th, 2008
hi,
I would like to know why does show version on WS-SUP720-3B shows
4 Virtual Ethernet interfaces
72 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
whereas in I can only see 48 port Gigabit Ethernet Interfaces and 2 Gigabit Interfaces (i.e. SFP modules).
Regards.
Correct Answer by Giuseppe Larosa about 8 years 7 months ago
Hello New,
to see physical ports you can use:
sh ip int br
sh int status
RT-TO-CRN-SF-E-1#sh int status
Port Name Status Vlan Duplex Speed Type
Gi3/1 Link -> SW-TO-CRN- connected 10 full 1000 1000BaseSX
Gi3/2 disabled 1 full 1000 1000BaseSX
Gi3/3 Failover link -> R connected 901 full 1000 1000BaseSX
Gi3/4 Stateful link -> R connected 902 full 1000 1000BaseSX
Gi3/5 Link FT x CSM connected 999 full 1000 1000BaseSX
Gi3/6 Link #1 -> RT-TO-C connected routed full 1000 1000BaseSX
Gi3/7 Link #2 -> RT-TO-C connected routed full 1000 1000BaseSX
Gi3/8 Link L1/L2 -> RT-T connected routed full 1000 1000BaseSX
Fa4/1 Link -> SW-TO-CRN- connected trunk a-full a-100 10/100BaseTX
Fa4/2 disabled 1 half auto 10/100BaseTX
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Sun, 10/19/2008 - 05:58
  • Hall of Fame,
    Founding Member
Hello New,
compare
sh version
sh module
Hope to help
Giuseppe
new_networker Sun, 10/19/2008 - 06:51
Still no clue..
SHOW VERSION
cisco WS-C6509-E (R7000) processor (revision 1.4) with 458720K/65536K bytes of m
emory.
Processor board ID SMC123600CH
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
SHOW MODULE
Mod Ports Card Type Model Serial No.
1 6 Firewall Module WS-SVC-FWM-1 SAD123502XJ
2 1 Application Control Engine Module ACE20-MOD-K9 SAD123500YF
3 8 Network Analysis Module WS-SVC-NAM-2 SAD12260338
4 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL12394FTB
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL12394QLZ
6 1 Application Control Engine Module ACE20-MOD-K9 SAD123500X9
7 8 Intrusion Detection System WS-SVC-IDSM-2 SAD11050B09
Giuseppe Larosa Mon, 10/20/2008 - 01:39
  • Hall of Fame,
    Founding Member
Hello New,
be aware that all services modules have internal connections via GE ports:
see this on one of my switches:
sh module
2 6 Firewall Module WS-SVC-FWM-1 SAD085008DY
3 8 8 port 1000mb ethernet WS-X6408-GBIC SAD03295602
4 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45 SAL0543DMSM
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAD0851097J
6 4 SLB Application Processor Complex WS-X6066-SLB-APC SAD071601PG
7 16 SFM-capable 16 port 10/100/1000mb RJ45 WS-X6516-GE-TX SAL08311CYB
8 48 48 port 10/100 mb RJ-45 ethernet WS-X6248-RJ-45 SAD03290204
9 1 Application Control Engine Module ACE20-MOD-K9 SAD1112028
sh ethercha sum
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
Number of channel-groups in use: 4
Number of aggregators: 4
Group Port-channel Protocol Ports
1 Po1(SU) - Gi5/1(P) Gi5/2(P)
2 Po2(RU) - Gi3/6(P) Gi3/7(P)
262 Po262(SU) - Gi6/1(P) Gi6/2(P) Gi6/3(P) Gi6/4(P)
271 Po271(SU) - Gi2/1(P) Gi2/2(P) Gi2/3(P) Gi2/4(P)
Gi2/5(P) Gi2/6(P)
each FWSM uses 6 GE, the CSM uses 4 GE and the ACE is not shown here for security reasons but you can expect it to use more then 6 ports.
in my case
RT-TO-CRN-SF-E-1#sh ver | inc Ethernet
28 Virtual Ethernet/IEEE 802.3 interfaces
96 FastEthernet/IEEE 802.3 interfaces
36 Gigabit Ethernet/IEEE 802.3 interfaces
1 Ten Gigabit Ethernet/IEEE 802.3 interface
RT-TO-CRN-SF-E-1#
I have only 8 GE external interfaces:
4 used by CSM
6 used by FWSM
ACE will use 8 GE or 1 Tengiga
Hope to help
Giuseppe
new_networker Mon, 10/20/2008 - 01:44
So which entry can I use to see the physical ports and the media type.
Regards.
Correct Answer
Giuseppe Larosa Mon, 10/20/2008 - 03:40
  • Hall of Fame,
    Founding Member
Hello New,
sh ip int br
sh int status
Hope to help
Giuseppe
