VPN Client connected but no ping nor access to privat network
Answered Question
Oct 19th, 2008
I have a 1802w installed, a VPN client wich can connect to the router and a connected L2L connection, wich works fine.
On the router I see that the client is connected, but no traffic is passing. In sh crypto ipsec, I see that traffic is decrypted, but no packtets are encypted.
Can anybody point me in the right direction? Attached I have the confs and debugs. Thanks for help in advance.
Erich
Correct Answer by ajagadee about 8 years 6 months ago
Erich,
Looking at your configuration, Couple of things:
1. Is this the current running configuration. I see your L2L Tunnel is configured with a match address of 101 but I do not see an ACL 101 defined on the router.
2. Your Split Tunnel needs to be reconfigured. Meaning, the source and destination needs to be swapped.
ip access-list extended SplitList
permit ip 192.168.2.0 0.0.0.255 192.168.111.0 0.0.0.255
Split Tunneling
http://www.cisco.com/en/US/tech/tk59/technologies_configuration_example09186a00800a393b.shtml#con4
Also, the pool of IP Addresses that you are assigning to the clients, make sure they are not part of a LAN on your side. If so, then you could run into routing issues.
Arul
** Please rate all helpful posts **
Overall Rating: 5 (1 ratings)
ajagadee Sun, 10/19/2008 - 13:10
  • Cisco Employee,
Hello Erich,
Can you attached the configuration and debugs. I dont see it attached to the post.
Arul
ezy Sun, 10/19/2008 - 19:36
attached the debugs and confs.
Erich
Correct Answer
ajagadee Mon, 10/20/2008 - 06:38
  • Cisco Employee,
Erich,
Split Tunneling
Arul
ezy Mon, 10/20/2008 - 20:25
Hi Arul,
thanks a lot. It was the split tunnel, I mixed it somehow.
Erich
