Howto Change Cisco ASA console baud setting
Oct 19th, 2008
How can I change the Cisco ASA Console baud setting. Is their a way like Cisco Routers. I do know how to do the same with the Cisco Routers.
Overall Rating: 5 (1 ratings)
ajagadee Sun, 10/19/2008 - 13:28
Hello Karim,
You cannot change the Baud Rate on the ASA.
The HyperTerm settings is:
Baud Rate: 9600
Data bits: 8
Parity: None
Stop bits: 1
I hope it helps.
** Please rate all helpful posts **
