IBM BC SW IOS BUG
Oct 19th, 2008
I noticed I could put the same network on two different vlan interfaces on the internal cisco IOS switch module. The IOS is cgedm.i6km-mz.12.21(22). I tried to do it again and was rejected. Is it an inconsistent bug?
smahbub Fri, 10/24/2008 - 10:19
Same network can be configured on two different vlan interface. Can you provide the error message you obtained while the config was rejected along with the network setup which will help in finding a better solution?
