EASY VPN on ASA5505
Answered Question
Oct 19th, 2008
hi all
I need to do configure a VPN between a branch (ASA5505) and a HO (VPN concentrator).
The IT gaved the following info for the configuration in the branch office,
USERNAME and PASSWORD
GROUPNAME and PASSWORD
and Peer Address.
So i deduced that they need an EASY VPN to be configured on the ASA5505
so i configured it with the following commands:
vpnclient server x.x.x.x
vpnclient mode client-mode
vpnclient vpngroup GROUPNAME password ********
vpnclient username branchvpn password ********
vpnclient ipsec-over-tcp port 10000
vpnclient enable
The VPN connected successfully and there is ping from LAN to LAN
but the client in the HO is telling me the following:
Other remote locations except your connection are having different IP range.
So when you are connecting from your branch to the HO VPN server, your IP subnet (i.e. 192.168.0.0) should publish in the network instead of taking the IP 172.17.0.0 from the VPN server as we have OSPF configured in our VPN Server.
172.17.4.0 Range is set for the VPN users.
Can any one advise what type of connection could be configured on the ASA, taking into the consideration the input that i was given and the requirement?
Correct Answer by Fernando_Meza about 8 years 6 months ago
Hi ..
try changing
vpnclient mode client-mode for
vpnclient mode network-extension-mode
That should solve the problem.
Please rate helpful posts !!!
Overall Rating: 5 (1 ratings)
Correct Answer
Fernando_Meza Sun, 10/19/2008 - 14:24
  • Gold, 750 points or more
Hi ..
try changing
