CSS config help - I am only able to access VIPs in 172.23.16.0 Subnet
Oct 19th, 2008
CSS config help - I am only able to access VIPs in 172.23.16.0 Subnet. For example I added the new VLAN 51, new services called cDCAEX01-SMTP and cDCAEX02-SMTP and new content rule and VIP called EXCHANGE-SMTP 172.23.26.51. Because thi si snot in 172.23.16.0 subnet I cannot access this VIP. I think I have a problem in my config because 1/1 is in VLAN 20 and 1/2 is a trunk carrying VLAN 51, 311, 315.
Do I need to make 1/1 also a trunk port?
ir
Do I shut down 1/1 and on 1/2 trunk port add VLAN 20 as well? Will this work?
Any other suggestions?
Config attached.
Overall Rating: 4 (1 ratings)
Gilles Dufour Mon, 10/20/2008 - 05:40
you have no default route on the CSS. That's suspicious.
Also, check with 'show summary' and 'show service-summary' that your new vip and services are alive.
See if you can ping the new vip.
Take a sniffer trace to see if traffic makes it to the CSS.
Gilles
astanislaus Mon, 10/20/2008 - 10:13
Gilles,
Thanks for your reply. You mean the CSS should have a default route pointing to VLAN20's IP address.
Can you please elaborate a little and may be add in some config commands for my understanding because I am not very familiar with CSS.
