Re: Defualt Routes Advertised by EIGRP ...
Oct 19th, 2008
The scenario I have is that I have the CE routers connecting to my core routers.
The devices are running EIGRP.
It looks like this :-
CE1 CE2
CR1 CR2
My core routers, CR1 and CR2 does not have a default routes injected to it.
How do I get my Core routers to have default routes advertised by EIGRP to it ?
Thank you,
Cheers,
- InternetB -
Overall Rating: 3.7 (3 ratings)
Calin Chiorean Sun, 10/19/2008 - 22:06
Hello!
On your CE router, on the interface towards core router, do the following:
ip summary-address eigrp 100 0.0.0.0 0.0.0.0
* 100 from the line above is the eigrp autonomous system number is just for example; you shoul use yours.
In this way the default route will be injected only towards core routers and not in other direction.
Good luck!
Cheers,
Calin
