10-20-2008 12:32 AM
Hi, I'm implementing a WAAS soultion and had planned on using the legacy WAFS acceleration used in 4.0, but have seen that 4.1 can use transparant CIFS acceleration. Can anyone tell me the pros and cons of each method?
I'm working to a very strict timetable with the deployment and it's the first one I've done since the training and my Windows/CIFS knowlodge is not great so I'm tempted to use the transparant acceleration but want to know what I'll lose in terms of fucntionality of I opt for the transparant acceleration.
Can I still use prepositioning or print services with transparant mode?
Many Thanks in advance
Dom
Solved! Go to Solution.
10-20-2008 05:30 AM
Dom,
The transparent mode in 4.1 reduces the operational overhead of configuring core and edge services along with adding and maintaining connectivity directives. The big pro with this new mode is that you now have bi-directional CIFS acceleration and can see all the CIFS connections under 139 and 445. They are not inside the 4050 connections between the core and edges.
Transparent mode does not support disconnected mode. You can still use prepositioning and print services with either mode. However, in WAAS 4.1.x for Print Services, there are extra options available with the Centralized Print Optimization AO as well as the Windows on WAAS Virtual Blade where you can run a full blown Windows Print servers.
Good info on the two modes can be found here⦠http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v411/configuration/guide/filesvr.html
Hope that helps,
Dan
10-20-2008 05:30 AM
Dom,
Hope that helps,
Dan
10-20-2008 06:28 AM
Thanks Dan
10-22-2008 02:16 AM
Am I right in assuming that the core device and the edge devices are configured the same when using transparant WAFS acceleration - ie I don't need to define one as the core device and the other as the edge device - they should both show up as application accelerators in the CM GUI?
