Rogue AP
Oct 20th, 2008
1.Is there any automatic process to detect and shun the clients or APs which are rogue?
2.Is there any link which can i follow?
3.What should be the ideal location of Rogue AP?
I am using WLC and APs.
Warm Regards
Asif Naveed
jeff.kish Mon, 10/20/2008 - 05:04
Unfortunately, there is no way to automatically contain any rogue device that pops up. Cisco's lawyers stopped them from doing that. You'll need to manually contain each rogue you find.
I'm not sure what you mean by an ideal location for a rogue AP. If you mean a rogue detector AP, just place them throughout your building, maybe one for every 2 or 3 APs you have in place. Remember that these only listen, they do not broadcast, so no channel configuration is needed.
Best of luck!
asif.naveed Mon, 10/20/2008 - 23:48
Thanks for your reply.
Actually i just need to know where should we place the Rogue AP i mean what is the ideal location of Rogue AP (talking about physical location)
asif.naveed Tue, 10/21/2008 - 03:26
Can we contain permanently Rogue APs.
Because if contain APs he comes again.
Is there any possibility......i want to contain even manually but permanently
Warm Regards
Asif
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
