10-20-2008 01:03 AM - edited 02-21-2020 03:59 PM
Hi Jazib,
May i ask you a question? I face an unsolved issue. After i tested using packet-tracer, below is the results;
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (ipsec-spoof) IPSEC Spoof detected
But when trying on "inside", it successful.
Let me draws out my issue;
server <-connect-> pix <-connect-> router <-> pix <-connect-> user
ipsec is between the outside leg of 2 pix fws
server using port 80,443 and 2000.
I encountered problem in access web services using 2000. It is ok for 80 and 443.
In pix, using packet-tracer. All 3 ports results are same. Me ipsec configuration is simple one. end to end.
Do you know what go wrong? Really appreciate for your advise and help.
Thank you.
Solved! Go to Solution.
10-24-2008 03:14 PM
port 2000 is used by skinny.if f/w sees some application running on tcp 2000 but it's not skinnt traffic,f/w will drop it.
Soln :
Disable inspect skinny
policy-map global_policy
class inspection_default
no inspect skinny
Do rate if helpful
Sushil
10-24-2008 02:18 PM
IPSEC Spoof detected:
This counter will increment when the security appliance receives a packet which should have been encrypted but was not. The packet matched the inner header security policy check of a configured and established IPSec connection on the security appliance but was received unencrypted. This is a security issue.
Recommendation: Analyze your network traffic to determine the source of the spoofed IPSec traffic.
Refer the following URL for more information on syslog message related to "IPSEC Spoof detected" being the reason for drop:
http://www.cisco.com/en/US/docs/security/asa/asa80/system/message/logmsgs.html#wp4772700
10-24-2008 03:14 PM
Soln :
no inspect skinny
Do rate if helpful
Sushil
