Syslog file grows very fast. How do i purge it regulary?
Oct 20th, 2008
I am running LMS2.5, my syslog file on this path "F:\Program Files\CSCOpx\log\syslog.log" grows very fast. How do i purge it regulary?
David Stanford Mon, 10/20/2008 - 05:10
  • Cisco Employee,
logrot is actually built in to LMS2.5
Check for it under CSCOpx\bin
To set it up run the command:
perl logrot.pl -c
After you configure it, add the task (logrot)to the windows scheduler to run it periodically
